Group: DynoMotion Message: 8879 From: Toby Rule Date: 1/10/2014
Subject: No Percent Sign or Program End
I have a .ngc file, and I launch the GCode interpreter on this file.  It throws an error “File ended with no percent sign or program end”.  Then when I launch it again, it works fine.
I am seeing this error on very rare occasions, and I’m not able to repeat it.  I think I’m probably just doing something stupid in my code, like trying to read from the file before writing is finalized, but I thought maybe you could provide some insight.
Toby
Group: DynoMotion Message: 8880 From: Tom Kerekes Date: 1/10/2014
Subject: Re: No Percent Sign or Program End
Hi Toby,
I assume you are using your own custom application?
I don't know.  As you mentioned if the file was not fully written and closed before executing then that would be the error you would receive.
